Ticking sound help
Old Jul 12, 2010 | 01:54 AM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Default Ticking sound help
So the blazer has developed a ticking sound. The tick seems to get louder when i give it gas, its a little hard to tell because of my loud exhaust, but i cant quite pimpoint where its coming from. i think it might be coming from the valves sticking. i went to Napa and they said it was probably a valve thats sticking. They told me to put a bollte of seafoam in the oil and let it run for about 20 minutes before i changed my oil. Should i do this? will it help any help would be awesome.
Old Oct 5, 2010 | 12:56 AM
jaybird33081's Avatar
jaybird33081 is on a distinguished road
I got the same problem. Did you ever get it fixed?
Old Oct 5, 2010 | 02:30 AM
okvortec's Avatar
Have you looked at the idea of an exhaust leak?
Old Oct 5, 2010 | 09:52 AM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
Well if it isn't something ratteling in the exhaust, remember little things make little noises, it could be a sticky valve, it could also be that something (probably a rocker) has some wear and tare on it and your hearing the gap clicking close somewere. This could be a # of things. The rockers could be worn, the lifters could be almost shot(if you have hydraulic lifters this could be an indication you are realy low on oil), or it could be a push rod that has bent a little. Best thing is pull the valve covers and rotate the engine by hand (breaker bar and socket) and check the lash on each valve at TDC of each cylinder, this is just time consumiing and annoying but it will more then likely tell you were the prob is.
bobomojo
Jun 16, 2014 01:03 PM
harley98
Apr 25, 2011 05:17 PM
mattd
Sep 15, 2009 06:54 AM
dubv25
Aug 11, 2009 08:45 AM
vdog
Jan 10, 2007 04:46 PM
