Timing adjustment issues
Old Apr 29, 2020 | 02:05 PM
Jackarpert's Avatar
Jackarpert is on a distinguished road
Default Timing adjustment issues
Hi
I have a 79 K5 that I had to put a brand new 350 in a few months ago. The timing has never been right since. Every time I turn it off it rumbles and shakes loudly for about a minute and then shuts off. Yesterday, using a timing light (for the first time) I set the initial timing to 12 at idle and went for a drive. It felt really good but I couldn’t get it above 40mph, it felt like all the power was lost. I then tried to reset it back toward what it had been set at (much higher than 12) and it ran roughly and shut off on me while driving then backfired loudly when I ultimately came to a stop. Please help!
Old Apr 29, 2020 | 06:12 PM
Are you disconnecting the vacuum advance before setting the initial timing? Also, if you rev the engine to 2500RPM or so, does the timing advance?
The dieseling (run-on) has nothing to do with the timing. Think about it for a second. When you turn the ignition off, there is NO spark. So it doesn't matter if the non-existent spark is advanced or retarded. It's generally caused by hot carbon deposits in the cylinders, combined with a too-high idle speed.There might be a vacuum-operated (or possibly electric solenoid) idle kicker on your carburetor. If it's adjusted properly, it should help.
Old Apr 30, 2020 | 03:37 AM
Would also need to know the setup.
OEM carb and ignition?
Aftermarket carb and ignition?
Steve Mabee
Jul 19, 2017 05:19 PM
tweet
Jun 22, 2010 09:57 AM
hotrodln
17
Apr 26, 2010 07:32 PM
Bmelz72k5
Mar 16, 2010 11:20 PM
yec
Sep 2, 2009 09:04 PM
