Timing bypass wire
on a '84? it's carb'd & vacuum.........no wire (that i remember.........)
you need to disconnect (& plug) the vacuum diaphragm for the advance (on the distributor), then check/set timing. once done, reconnect the vacuum hose to the diaphragm.
i thought you said your truck was a '84 Dan? i've never come across a carb'd vehicle with an ECM.
The early carbed California vehicles had a computer and an electronically controlled carb. It's an E2SE instead of a 2SE carb. Didn't see anything in the manual about anything different with the timing thiugh.
Hey so you are saying it is vacuum advanced Gimpy? I am just thinking it is electrical because I do not see a vacuum line going to the distributer. It would be pretty obvious to see right? Also I sent you the email address to send the adjustments for the carb.
Doctorvette
Nov 5, 2012 11:57 PM
Denominator
Sep 23, 2010 02:40 PM
hotrodln
17
Apr 26, 2010 07:32 PM
Denominator
Apr 25, 2010 06:31 PM
