Timing question
Timing question
O.K I really need some help! I have three guys trying to tell me that the timing chain dots are not supposed to be lined up like in the book as close to each other as possible. i have the cam gear dot facing the bottom and the crank gear dot facing the top like in my book. is this wrong?? please let me know! I could really use the help!
the cam dot needs to be at 6 oclock and the crank needs to be at 12 oclock see this thread https://blazerforum.com/forum/showth...ng+chain+marks
THANKS!
I knew I set it up right! Know I just have to figure out why it wont start up now!
Make sure its on the compression stroke or you will be 180 degrees off when the distributor is installed.
Doctorvette
11-05-2012 11:57 PM
Denominator
09-23-2010 02:40 PM
hotrodln
17
04-26-2010 07:32 PM
Denominator
04-25-2010 06:31 PM
