tranny compatability between engines
Old Apr 2, 2009 | 02:51 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default tranny compatability between engines
I have the 2.8L engine with the 700R4 (4x4) tranny. I plan on going to a junkyard this weekend for a replacement tranny. If I cant find any other 2.8 4x4, will the 700r4 from a 4.3L work just the same or no? What else can I look for?
Old Apr 2, 2009 | 03:31 PM
No. The 2.8L v6 is a 60* V engine while the 4.3L v6 is a 90* engine. The bell housing of the 4.3L is noticeably wider than that of the 2.8L.
Old Apr 2, 2009 | 03:46 PM
rriddle3's Avatar
I believe a trans from a rear-drive 3.4L would match up to the 2.8L, wouldn't it?
Old Apr 2, 2009 | 05:31 PM
bobditts's Avatar
would the rear drive 3.4L be 4x4 capable?
Old Apr 2, 2009 | 07:00 PM
The engine? sure. A 2wd 700R4 from behind a 3.4L, not without pulling all of the guts out of it first to swap the tail shaft.
Old Apr 2, 2009 | 07:12 PM
bobditts's Avatar
so im pretty much stuck looking for a 2.8L 4x4 700R4 and nothing else huh?
Old Apr 2, 2009 | 07:20 PM
A 700R4 from any 60* v6 will work, but a 4wd version will be the only thing that will bolt up without changes.
chevyguy90
Jun 20, 2010 07:59 PM
tawd77
Mar 21, 2008 06:29 PM
ginobass
Sep 19, 2007 09:55 AM
Jman
Jul 3, 2007 10:33 AM
sfox
May 13, 2006 01:20 PM
