Tranny going out??
Old Apr 10, 2007 | 06:42 AM
minijosh's Avatar
minijosh is an unknown quantity at this point
Default Tranny going out??
While driving to church, I stopped at a stop sign and hit the gas. First gear was fine and then second gear seemed to hesitate and so did 3rd. I just found out my cat is going out so there's something that needs replacing. My gearbox is what is freaking me out. I've found 2 kids on rockauto.com
ACDELCO Part # 24229853
SHELL KIT,REACTION SUN GR w/4-SPD A/TRANS(M30)
$205.79
$0.00
$205.79
[/align]
ACDELCO Part # 24231452
CASE KIT,A/TRNS w/4-SPD A/TRANS(M30)
$487.99
$0.00
$487.99
Which one do I need? The case it or the shell kit?
Old Apr 11, 2007 | 01:17 AM
Hanr3's Avatar
Default RE: Tranny going out??
Fix the cat first.
The puter reads all the sensors and adjusts the engine and tranny to correct for many things. That hesitation could very well be caused byyour cats poor performance.
FYI- to replace the sunshell you have to take the tranny apart.
Old Apr 11, 2007 | 04:58 AM
minijosh's Avatar
Anyone know a good place to get a performance cat? I want a direct bolt on to the stock exhaust so I can change it.
Old Apr 12, 2007 | 12:20 AM
Hanr3's Avatar
Cats are welded on from the factory.
Check your local autoparts store or Summit Racing for a universal cat and universal connection kit. Ask them to explain to you haow it works. See if that is what your after, if not, tell them what you want to do.
kaalbin12
Mar 7, 2013 01:33 AM
VonBerry
Sep 27, 2011 11:10 PM
andrew_as
Mar 30, 2009 04:24 PM
BLK85
Mar 26, 2007 01:59 AM
consernedguy
Nov 6, 2006 11:19 PM
