tranny problem?
Old Apr 9, 2007 | 12:34 PM
kelraes's Avatar
kelraes is an unknown quantity at this point
Default tranny problem?
I just replaced tranny filter and fluid now i have code P0758. Its a shift solenoid. does anyone know where I can get this part and how much it cost.
2001 Blazer LS
4.3L 4X4
2Dr
Old Apr 9, 2007 | 05:29 PM
kelraes's Avatar
Default RE: tranny problem?
Also how hard is it to change the sensor?
Old Apr 11, 2007 | 01:25 AM
Hanr3's Avatar
Make sure your tranny is full of fluid first. Parked on level ground after 20minutes of driving with the engine running. Now check the fluid level. Bottom of the cross hatch to the top of hte cross hatch is 1 pint (1/4 of a quart bottle).
Did you use gasket maker on the tranny pan gasket?
If so, stop immediately. Remove that gasket sealer now. There is a drain back hole in the bottom of the tranny housing with a notch in the gasket to go around it. If you got sealer in that little hole, you WILL fry your tranny.
If neither of those apply. Did you replace the old filter gasket? The one stuffed up in the case? Did you get the old one out before you stuffed the new one in?
ski.dive
Feb 7, 2014 05:18 AM
bouser
Dec 10, 2009 11:46 PM
lovetheblazer
Mar 13, 2006 01:00 PM
sting_da_man
Mar 13, 2006 12:48 PM
nine5blazer
Oct 18, 2005 05:19 AM
