Tranny service
Old Aug 7, 2008 | 12:05 PM
kbreck's Avatar
kbreck is an unknown quantity at this point
Default Tranny service
After how many miles should the tranny be serviced and what's involled and how much $$$
Old Aug 7, 2008 | 12:59 PM
rriddle3's Avatar
Default RE: Tranny service
I like to have a pan drop with fluid and filter change ~30,000 miles. The Chevy dealer near me charges $80.
Old Aug 7, 2008 | 01:01 PM
The filter really isn't necessary, but whenever I have a pan off, I replace the filter. Installing a drain plug when you first service the transmission allows for much easier fluid changes.
Old Aug 7, 2008 | 01:03 PM
rriddle3's Avatar
I keep threatening to install a plug, but...you know.
Old Aug 7, 2008 | 01:07 PM
I'm getting ready to service the trans on my Rainier here at some point. I plan on welding on a nut and using a typical oil pan drain plug probably cut down. I will also be epoxying a neodymium magnet to the plug so I can monitor the health of the bands and the torque converter clutch. With regular fluid changes, I do not suspect problems with either of these areas.
Old Aug 7, 2008 | 01:13 PM
rriddle3's Avatar
Neodymium? Come on Kyle, don't go cheap. Get the unobtainium one.
Old Aug 7, 2008 | 01:20 PM
Neodymium is good enough for me.
*EDIT* - You had me thinking I spelled it wrong. I just read up on them and they seem to lose their magnetism at relatively low temperatures... Maybe I will not be using that kind of magnet after all.
Brian5792
Sep 13, 2017 07:03 PM
ski.dive
Feb 7, 2014 05:18 AM
98BravadaST
Jan 16, 2010 12:35 PM
blazerboy30
Apr 8, 2008 05:30 PM
tbirr
Engine & Internal
Apr 8, 2006 03:31 AM
