tranny swap
Old Feb 22, 2020 | 03:57 PM
inthepaint's Avatar
inthepaint is on a distinguished road
Default tranny swap
This will sound crazy but i want to swap my custom 84 K5 5 speed manual to a 700R4 auto.....tranny, torque converter, drive shaft....is the transfer case the same? I realize its involved but if im going to use the truck i need to do it....would appeciate any advice. thanks
Old Feb 22, 2020 | 07:03 PM
What 5-speed and what transfer case are you running now?
Old Feb 23, 2020 | 07:34 PM
inthepaint's Avatar
Thanks Tom.......currently has NV4500 5 speed......transfer case stamp is C 15085 --says new process gear on round metal tag
Old Feb 23, 2020 | 07:40 PM
I would love to take that 5-speed off your hands, but I don't have a 700R4, just a 4L60E.
Can you post a picture of that round tag? Chances are, that transfer case will be fine with the 700.
Old Feb 24, 2020 | 12:30 AM
inthepaint's Avatar
i'll have to figure out how to post pics.....im up in British Columbia but the K5 came from Arizona.....
Old Feb 24, 2020 | 10:03 AM
No big deal if you can't post a pic, but the tag should have three digit number (with letters attached) like 241, 208, etc. Might be NP241C or something like that.
I think the problem you're going to encounter is that your current transmission output is 32-spline and the 700R4 is 27-spline.
Old Feb 24, 2020 | 02:40 PM
inthepaint's Avatar
Tom......208 C is model #
Old Feb 24, 2020 | 02:49 PM
You'll have to change the transfer case input to a 27-spline and get the right adapter for the 700R4, but both parts are relatively inexpensive and readily available.
You're also going to need to provide for operation of the TV cable (throttle linkage) and do something for a shifter if you don't already have an auto column.
Your crossmember may have to be moved or modified, and I don't know how the driveshaft lengths will work out, but all said, it's a pretty easy swap
Old Feb 24, 2020 | 03:06 PM
inthepaint's Avatar
Much appreciated Tom...it'll be spring before i tackle this but will post the results........thanks again.
Old Feb 24, 2020 | 03:14 PM
No problem. And good luck!
r_marczak_83
14
Feb 2, 2013 10:28 AM
newguy
Aug 31, 2012 05:38 AM
fst450
Mar 11, 2009 05:01 AM
RicanGSXRDude
Oct 3, 2008 06:07 AM
oldsledman
Apr 6, 2007 05:29 PM
