tranny swap
Old Aug 6, 2007 | 11:27 PM
middleman496's Avatar
middleman496 is an unknown quantity at this point
Default tranny swap
Hey guys!! new to the blazer forums. i was wondering if anyone can help me out,i need to make aparts list on what i needfor aA/T to M/Tswap for my '97 Jimmy 2wd4 dr. and what is the easiest way to change my spark plugs thanks for your help
Old Aug 6, 2007 | 11:41 PM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
Default RE: tranny swap
let me see if i can help
trans
clutch
throwout bearing
new flywheel
pedal assembly
im not sure if blazers are hydraulic or cable
if theyre cable you need a cable (duh)
slave cylinder
if its hydraulic i know you need the
resevoir
lines
slave cylinder
i dont know what to do with all the electrical stuff from the AT
hopefully this helps a little
and as far as plugs, go from the wheelwell. makes it real easy
Old Aug 7, 2007 | 07:53 AM
Well, that is the jist of it anyway... You'll probably want to have a PCM from a 2dr M/T truck of the same year to swap in as well... I'm not sure how the PCM would like not having an A/T any longer...
One other thing that has yet to be verified is if the driveshafts are the same length between the A/T & M/T. If they are not, you are going to need your driveshaft lengths modified for proper fitment. A M/T was never offered in the 2nd gen 4dr.
ski.dive
Feb 7, 2014 05:18 AM
jccuban13
May 12, 2008 03:52 PM
oldsledman
Apr 6, 2007 05:29 PM
91 Streeter
Engine & Internal
Feb 1, 2007 10:56 AM
KA3AX
Apr 1, 2006 11:53 AM
