tranny swap??
Old Apr 1, 2008 | 11:26 AM
tx78k5blazer's Avatar
tx78k5blazer is an unknown quantity at this point
Default tranny swap??
ok... so i have a 78 Blazer 4WD400CID enginewith a TH350 trans... I have a buddy that has a Turbo 400 trans with stage 2 shift kit freshly rebuilt.... it is not for a 4WD truck tho... will it fit and what do i need to make it fit? or should i just look for a 350 trans?
Old Apr 1, 2008 | 12:45 PM
BigBlack73's Avatar
BigBlack73 is an unknown quantity at this point
Default RE: tranny swap??
It would fit but you would probably need to give up 4WD in your blazer, unless there is a way to convert it so that you could mount your transfer case on it. GM made those trannies pretty universal. I just put an SM465 with an NP205 Transfer and it's the best combination i could imagine...
Old Apr 1, 2008 | 01:00 PM
WolfPack's Avatar
I know in the s-series, if you try to get a 2wd tranny to put in a 4wd...you need a new driveshaft..can't remember if it's either shorter or longer.
ski.dive
Feb 7, 2014 05:18 AM
middleman496
Aug 7, 2007 07:53 AM
oldsledman
Apr 6, 2007 05:29 PM
91 Streeter
Engine & Internal
Feb 1, 2007 10:56 AM
KA3AX
Apr 1, 2006 11:53 AM
