tranny swap
Old Apr 26, 2010 | 05:31 PM
witsblazer's Avatar
witsblazer is on a distinguished road
Default tranny swap
can i put my t350 tranny in my 99 blazer 4x4 and what will i need to do it if i can. besides wiring and computer work...
Old Apr 26, 2010 | 07:04 PM
abig84's Avatar
Might have to change output shafts. Its the same spline count but doubtful its gonna be the same length. Also the th350 is shorter so gonna need new driveshafts and move or make new crosmember. Not sure if its gonna mess ith your computer. The vss is in the transfercase
Old Apr 27, 2010 | 06:04 AM
Either output shaft change or a transfer case swap.
The PCM will have to be reprogrammed to a manual tune so it doesn't complain about not having control over the trans.
Old Apr 27, 2010 | 01:22 PM
witsblazer's Avatar
yeah that sounds right, but im not even sure what the real problem is with mine i replaced the spiders and pininon rebuild everything in the rear end and it chutters still when i reverse is that a reverse drum in the tranny cuz i just had it rebuild 5000 miles ago
Old Apr 27, 2010 | 01:27 PM
Have you checked all of your engine & trans mounts?
ski.dive
Feb 7, 2014 05:18 AM
middleman496
Aug 7, 2007 07:53 AM
oldsledman
Apr 6, 2007 05:29 PM
91 Streeter
Engine & Internal
Feb 1, 2007 10:56 AM
KA3AX
Apr 1, 2006 11:53 AM
