Trans Coolant Line Help
Old Apr 27, 2011 | 10:08 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Default Trans Coolant Line Help
I had a small hole taken out of my coolant line that runs to the top of the radiator today (within a block of my house for the test run after installing my new suspension and steering parts). I believe I need to drop the trans to replace the hose. I have the replacement part, but I'm wondering if I should have this done by a professional. I also plan on changing the filter and obviously new fluid after the problem is fixed.
So, in short...Should I try to get it to a trans mechanic and how do I patch it to make it there?
Thanks,
Steve
Old Apr 28, 2011 | 09:12 AM
abig84's Avatar
I wouldn't think you would have to drop the trans for that. If its one of the metal lines running from the trans there's always a way to patch it. If its in the rubber line you can cut out the bad spot and put a metal line in there and hose clamp it. If its the metal line cut it out and use a rubber line with clamps. Usually if done right should hold up for years. Usually just starts leaking cause the clamps need to be tightened
Old Apr 28, 2011 | 04:17 PM
It's in the metal right next to the starter. My dad brought home a few clamps and I'm about to put one on and see how it works. I'm glad to hear it will last a while though.
madmaxxed
Oct 14, 2014 06:52 AM
AcerDeucerQ
Dec 3, 2012 06:29 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
LS1BadBird
Feb 20, 2010 06:00 PM
rastaskater
Jan 29, 2008 08:32 AM
