Trans Cooler Hose Size
Old Nov 7, 2010 | 02:28 PM
biniecki's Avatar
biniecki is on a distinguished road
Default Trans Cooler Hose Size
I have a '96 Chevy Blazer with a 4.3L that is 4x4. The previous owner used the wrong size rubber hose on the transmission cooler. I know its the wrong size for multiple reasons. First the diameter is too small to fit over the fittings but he forced it and clamped it. This caused a problem for me. While driving the other day the hose blew off and its impossible to get it to stay on without blowing off again. I jerry rigged it by bypassing the cooler to get home. I want to replace the lines with the right size now. Does anyone know what the diameter is of the hose I need?
Old Nov 7, 2010 | 03:02 PM
69chevelle's Avatar
69chevelle is on a distinguished road
is it just slid over the factory metal lines? if it is, make sure you flare the end good to make sure it doesn't blow off or leak....
I used compression fittings on my lines with a ****** end on it. (what was available to me) and don't have any leakage issues.
Old Nov 7, 2010 | 04:37 PM
biniecki's Avatar
I just needed the rubber hose the goes from in between the metal hose and the cooler. I just looked up the specs for the metal hose and found out that it has a 3/8" end on it. I got some 3/8" hose and took care of the problem. The previous hose was 5/16"
Old Nov 9, 2010 | 02:23 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
just curious, what size is your tranny cooler?
Old Nov 9, 2010 | 08:31 PM
69chevelle's Avatar
mine is WAY overkill. if u want a pic let me know. it's easily 1/3 the size of the rad.. but it was free my tranny temps hit 250+, haven't gone over 200 since(while towing, logging roads it got the hottest) although one with a bypass valve is what you want, cold temps aren't good for the transmission either(bypasses the cooler until it hits a certain temp)
Old Nov 10, 2010 | 08:22 AM
biniecki's Avatar
Mine sounds like the same thing. Its about a third the size of the radiator.
ComputerNerdBD
Jul 24, 2011 03:51 AM
m.sterner
Nov 29, 2009 10:34 PM
Ugly_Monkey
Feb 28, 2009 08:42 PM
luthers97blazer
Nov 10, 2008 01:27 PM
Jetfixer
Jul 11, 2006 05:02 AM
