trans fluid
Old Apr 28, 2008 | 11:34 PM
Loofah's Avatar
Loofah is an unknown quantity at this point
Default trans fluid
My transmission seems to consistently leak fluid needing to be replenished, but it isn't leaking it on the ground so I can only assume it's going into the transfer case. This possibility was confirmed by a mechanic, does anyone know what could be done to prevend this and what the negative effects this could have on either the transmission or transfer case? Thanks!
Old Apr 28, 2008 | 11:38 PM
Loofah's Avatar
Default RE: trans fluid
i apologize i missed the post just below mine. Does anyone knwo how many hours should be planned for to remove the transfer case to replace the gasket?
BrinkDiamond
Mar 2, 2014 03:50 PM
Mjseyler
Jan 5, 2010 12:44 PM
DaleA
Jan 13, 2009 08:50 PM
luthers97blazer
Nov 10, 2008 01:27 PM
v8vairman
Apr 12, 2006 01:43 PM
