trans line leak
Old Jul 20, 2011 | 06:57 AM
garryb's Avatar
garryb is on a distinguished road
Default trans line leak
i have a 2000 blazer and the lower radairter trans line is leaking. it is the type that slips in and the c clip holds it in. can i replace just the fitting or do i have to replace the rad also or is there just a oring i can replace thanks
Old Jul 20, 2011 | 07:37 AM
I have never seen one leak, but there is an o-ring inside that seals off on the nose of the tube when it's installed. It's a pain to get out and almost as hard to get back in. You'll need a VERY small right angle pick to get in there and behind the o-ring to pull it out. It's possible that you just have something in there preventing the seal?
Old Jul 20, 2011 | 08:39 PM
garryb's Avatar
thanks . can i remove the fitting or is it not removeable? i cant tell if it will screw in and out .
Old Jul 21, 2011 | 02:01 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
Since its the lower, I would bite the bullet and pull the radiator. Flush it while your replacing the oring. Couple hours of work
Old Jul 21, 2011 | 07:36 AM
Yes, the fitting can be removed/replaced.
Old Jul 22, 2011 | 01:54 AM
kristoph30's Avatar
I wasnt aware you could pull the filtting out. 4 Blazers and never tried!
midnightbluS10
Dec 20, 2010 11:43 AM
amplexis_0081
Dec 28, 2009 11:17 PM
maroon_blazer
Oct 5, 2009 07:10 PM
oshkosh
Sep 4, 2009 10:27 AM
bigmick
Sep 1, 2009 08:37 PM
