Trans line leakage at radiator
Old Sep 1, 2009 | 04:44 PM
bigmick's Avatar
bigmick is on a distinguished road
Default Trans line leakage at radiator
ok, so my 2000 chevy blazer was having cooling problems and i finally diagnosed after changing everything else that it was the radiator... so ordered and changed it and cooling is great never exceeds 200º now... but i noticed now i have a transmission fluid leak from the bottom trans line, i positive its seated... any suggestions? should i just take apart and reassemble?
Old Sep 1, 2009 | 08:20 PM
Cross threaded connection?
Old Sep 1, 2009 | 08:37 PM
AJBert's Avatar
If you've got crossed threads, you will need to replace both fittings. If they aren't cross threaded, you might want to try using an o-ring. Just make sure the o-ring can handle the pressure (not terribly high) and the trans oil.
LesMyer
Dec 10, 2014 10:49 PM
midnightbluS10
Dec 20, 2010 11:43 AM
RyanHowell
Sep 1, 2009 02:05 AM
gmbwrenchn
Apr 20, 2009 07:06 PM
antweber29
Dec 26, 2008 10:12 PM
