Trans. shifting hard on an automatic?
Old Apr 19, 2011 | 09:53 PM
cory.kiel's Avatar
cory.kiel is on a distinguished road
Default Trans. shifting hard on an automatic?
i have a automatic tranny and when it shifts into 1st gear it jerks my entire car for some reason. also when im accelerating my engine will rev really high to the point where my foot is on the floor and i still am not going any faster. but then it would shift really hard. i have no clue as to why.
Old Apr 20, 2011 | 04:13 AM
BlazerWare94's Avatar
BlazerWare94 is on a distinguished road
mine every once in a while jerks out of 1st and thats the only problem i have with mine... this one guy told me supposedly my tranny is missing some spring that returns idk watt so it can shift smoother.. ... idk if it might be the same going for u..
have u checked the tranny fluid? maybe it doesnt have enough pressure build up to shift gears.? idk im just sayy'n
Old May 10, 2011 | 12:54 PM
danieltramel's Avatar
danieltramel is on a distinguished road
my blazer was doing the same thing shifting hard from 1st - 2nd did trans service still the same friend of mine told me to ohm my trottle position sensor to check for an erratic reading sure enough it was bad changed it and the tranny shifts smoother now and the spring the other guy mentioned is 1-2 3-4 accumilator spring
Old May 11, 2011 | 09:34 AM
cory.kiel's Avatar
you say ohm ? i dont know what that stands for or means....lol and for the springs would i have to crack open the tranny to look and or to fix? same with the sensor?
Old May 12, 2011 | 11:37 AM
amnotblonde's Avatar
amnotblonde is on a distinguished road
OHM is the measure unit of resistance. Have you checked for error codes? If yes, have you received an error like P0751, Shift Solenoid A Performance Problem?
Service Manual says:
Component & Wiring Harness Resistance Check
1) Install Jumper Harness (J-39775) to transmission 20-pin
connector. Using an ohmmeter, measure resistance between specified
terminals for each component.
and
If resistance reading is okay, go to next step. If
resistance reading is not okay, disconnect wiring harness at component
and measure component resistance. Replace component if resistance is
not as specified. If resistance is as specified, repair wiring harness
between component and 20-pin connector.
Old May 12, 2011 | 06:34 PM
i miss directed you did not look at year of your blazer sorry have you tried to adjust your t.v. cable you can find the procedure in most repair manuels
Old Jun 17, 2011 | 11:41 PM
clifflys's Avatar
clifflys is on a distinguished road
some transmissions use a vacuum modulator to adjust oil pressure.Check if yours has one and check vacuum line to it.
Workinwillys
Oct 27, 2014 09:06 AM
ewhittaker
Nov 29, 2012 08:50 AM
gmbwrenchn
Dec 2, 2010 07:16 PM
75 blazer
Aug 13, 2010 06:36 AM
96jimmy4x4in
Oct 7, 2007 09:23 PM
