Notices
Rebuilt trans. shifting hard
Old Oct 18, 2010 | 07:41 PM
gmbwrenchn's Avatar
gmbwrenchn is an unknown quantity at this point
Default Rebuilt trans. shifting hard
Just had a rebuilt trans. installed in my 2001 Lumina 3.1 ltr. $1300 bucks worth including a new torque converter. I think it was a pretty good deal. It seems to shift kinda hard all through the gears....with a slight jerk. Is this normal after a rebuild? Will it get better with time or do I need to address this ASAP with the shop. Or can I check something first. Did check the fluid, a-ok. Just want to get some info before I give them a call.
Old Oct 18, 2010 | 11:18 PM
oktain's Avatar
Shop should garauntee it's work, go back and ask politely why it seems to be shifting hard since your rebuild.
Old Oct 19, 2010 | 02:32 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
It depends on what type of parts they put in the tranny. Actually if the gears slam together a little they will surprisingly last longer, however the drive train parts don't enjoy it as much so they wear out faster. But I would go back to the shop and inquire why it is acting that way, just to be on the safe side.
Old Oct 20, 2010 | 08:10 AM
oktain's Avatar
Politely
Old Oct 26, 2010 | 09:11 PM
gmbwrenchn's Avatar
Is this a 3 speed trans or a 4 speed. Crusing on the freeway @ 65 mph the rpm's are at about 3000. Does that sound right? Is something missing when they did the rebuild?
Old Oct 27, 2010 | 07:17 AM
4 speed automatic. RPMs depend on gearing and tires. At 60MPH with 3.73 gears in my old Bravada, I would be around 2000RPM. With the torque converter unlocked, this would rise about 300-400RPM.
3rd gear is direct 1 to 1 gear ratio through the transmission. It sounds like you don't have 4th.
Old Oct 27, 2010 | 03:36 PM
gmbwrenchn's Avatar
Here is one other thing too. While crusing on the freeway in overdrive, if I would shift into drive there is no RPM change either.
What would be the cause of 4th gear missing? Adjustment? Just want to get a little educated on this before I give them a call, thanks.
Last edited by swartlkk; Dec 2, 2010 at 08:38 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 2, 2010 | 07:16 PM
gmbwrenchn's Avatar
Looks like it ended up being a bad pump in the trans.
ewhittaker
Nov 29, 2012 08:50 AM
cory.kiel
Jun 17, 2011 11:41 PM
Ugly_Monkey
Apr 20, 2009 10:40 PM
Blazer_98
Oct 23, 2007 02:37 PM
96jimmy4x4in
Oct 7, 2007 09:23 PM
