trans slips 2000 4x4 blazer
Old Sep 2, 2010 | 03:19 PM
e1j1r1's Avatar
e1j1r1 is on a distinguished road
i went and had my filter done change of fluid also now the transmission wont shift from 2 to 3 or 4 can anyone help
also i need to know how to take brake light switch off thanks
Last edited by swartlkk; Sep 2, 2010 at 06:19 PM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post if another member has yet to reply.
Old Sep 2, 2010 | 06:20 PM
What are you driving??
Old Sep 3, 2010 | 09:47 AM
e1j1r1's Avatar
Default tranny or switch
iam driving my camaro now but my 2000 4x4 blazer is down with this problems
Old Sep 3, 2010 | 10:07 AM
When you are asking for support with your vehicle, knowing the vehicle info is crucial!
So you have no upshift out of 2nd. Does it slip or just stay in 2nd gear without attempting to shift?
A "No 2-3 Shift or 2-3 Shift Slips, Rough, or Hunting" condition could be caused by:
  • Internal damage to the torque converter
  • Oil pump stator bushings scored or off location
  • Valve body assembly 2-3 shift valve train stuck, gaskets or spacer plate incorrect/mispositioned/damaged, 2-3 accumulator valve stuck, or face not flat
  • Input housing assembly 3-4 clutch or forward clutch plates worn, excessive clutch plate travel, cut/damaged 3-4 clutch or forward clutch piston seals, porosity in input clutch housing or piston, 3-4 clutch piston check ball stuck/damaged/not-sealing, restricted apply passages, forward clutch piston retainer and ball assembly not seating, or sealing ***** loose or missing
  • 3rd accumulator retainer and ball assembly not seating in transmission case.
  • 2nd apply piston seals missing/cut/damaged in 2-4 servo assembly.
AutomagicLS1
Aug 1, 2013 04:53 PM
Skully69
Sep 23, 2009 10:45 AM
Masterblaster1
May 26, 2009 12:07 PM
rob1621
Feb 29, 2008 08:15 PM
Sparky
Jan 13, 2007 09:08 PM
