Trans temp gauge
Old Apr 3, 2010 | 02:30 PM
ComputerNerdBD's Avatar
ComputerNerdBD is on a distinguished road
Default Trans temp gauge
Hey everyone. Is there a way of installing a trans temperature gauge without dropping the pan? Is there one that is an inline setup that attaches to a transmission line? I have a B&M transmission cooler that is installed on the passenger side grille with the fittings pointed down (please see the album in my garage for a photo). The hoses are run from the cut trans return line near the oil filter to the cooler and from the cooler to the radiator trans return port.
Old Apr 4, 2010 | 02:38 PM
Hanr3's Avatar
There is a test port above the shifter linkage on the drivers sdie of the tranny, its a 1/4" plug. Remove that and put in your temp sensor. Most kits will identify this location for the sensor.
Old Apr 5, 2010 | 05:21 PM
neo71665's Avatar
Where I put mine and it works fine.
Old Feb 27, 2011 | 04:40 PM
dj00140's Avatar
dj00140 is on a distinguished road
Im getting ready to do this to, does the plug screw right into the test port or how does it attach? Thanks.
Old Feb 27, 2011 | 04:53 PM
The plug that currently is installed in your test port is threaded.
Old Feb 28, 2011 | 11:11 AM
dj00140's Avatar
Sweet anyone know a good gauge to buy? I was looking at this one:
http://www.summitracing.com/search/V...ATM-3357&dds=1
Here is a great tutorial!
http://www.keystonekrawlers.com/Mods...Temp_Guage.htm
Old Feb 28, 2011 | 12:16 PM
TZFBird's Avatar
TZFBird is on a distinguished road
It appears the pressure port is a fairly easy place and is located shortly after pump output. My only concern is how far down the case the port is after the pump. I can't remember exactly where it's located in relationship to pump depth in the case. I only raise the question because the fluid has no flow in this port so if you are looking for fluid temp that is as accurate as possible, you may want to consider something else (depending on the probe distance from the pump). I would only raise that concern in a racing or heavy-duty towing application where temperatures could skyrocket before the gauge reflects the change.
hoppy26
Jan 26, 2012 02:08 PM
zakm0n
Jan 9, 2011 07:31 PM
Malachai
Mar 27, 2010 10:00 PM
mboehler
Jan 16, 2009 07:16 AM
Mulisha
Mar 24, 2008 09:14 PM
