transfer case
Old Mar 25, 2008 | 01:36 PM
gorman317's Avatar
gorman317 is an unknown quantity at this point
Default transfer case
for a 96 blazer what would be the best way to drop the transfer case? would i drop it then remove all the plugs or remove the plugs then drope it?
Old Mar 25, 2008 | 06:47 PM
Default RE: transfer case
Its 6 to one, half a dozen to the other. The fluid will add weight and slightly to the awkwardness of the transfer case, but it already is quite awkward and the fluid doesn't make up that much of the over all weight. Either way will work and if you are already planning on replacing the fluid, might as well drain it before you move on to taking the thing out.
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
bob2231
Nov 6, 2005 04:40 PM
loscochinos520
May 28, 2005 11:32 PM
buckwheat
Jan 6, 2005 04:59 PM
