transfer case fluid
Old Apr 12, 2011 | 05:10 PM
motoart1's Avatar
motoart1 is an unknown quantity at this point
Default transfer case fluid
I have a 1984 kfull size blazer with an np 208 transfer case. I recently pulled the transfer case to reseal the transmision to transfer adapter. i was told to replace the transfer case fluid with 10/30 motor oil. I noticed now it tends to grind when shifting the transfer case. Would to heavy anoil cause this? Did I get bad info?
Old Apr 12, 2011 | 07:09 PM
chris015's Avatar
I believe you need dextron atf fluid. Or at least thats whats in mine and many others. that 10 30 might be to thick to flow through the chain.
Flyfishen
Jun 18, 2019 11:22 AM
DaleA
Jan 13, 2009 08:50 PM
AutomagicLS1
Engine & Internal
Dec 1, 2006 11:08 PM
blazerium
Nov 20, 2006 11:10 PM
Marcin
Oct 14, 2006 06:09 PM
