Transmission from a '01 swapped into '96: Will it work?
Old Oct 6, 2009 | 04:33 PM
JimmyBlaze's Avatar
JimmyBlaze is on a distinguished road
Default Transmission from a '01 swapped into '96: Will it work?
I have the opportunity to buy a transmission from a '01 Blazer to replace the now blown unit in my '96 Jimmy. Will it work if the '01 has the 4L60e? What about if it has the 4L65e?
Thanks!
EDIT: Will a swap from a '97 Blazer be more straightforward? What year did the bell housing become removable? I believe that on my '96 the bell housing is not removable. Can I use the trans from a blazer or Jimmy that came equipped with a removable bell housing?
I appreciate your responses!
Old Oct 6, 2009 | 05:14 PM
You should be able to use the '01 trans in your '96. The transmission will have the removable bell housing, but should bolt up just the same. You may have to make a dust shield for the front.
A '97 swap would be a direct replacement, but the '01 trans has improvements over the '96 & '97 models.
arnolopolis
Jul 22, 2015 01:29 AM
yask4it
Aug 22, 2009 02:21 PM
Vahomboy
Jul 16, 2009 08:10 AM
Ridinblazer
Nov 8, 2008 04:52 PM
AutomagicLS1
Apr 24, 2008 05:19 AM
