Transmission
Old Mar 25, 2018 | 09:28 PM
1997chevblazer's Avatar
1997chevblazer is on a distinguished road
Originally Posted by Transman304
You’re very welcome. Let us know how it works out.
it seems to be working so far when you put the car in gear it takes about 5 seconds for it to click in and move but other than that it’s working good so far
Old Mar 26, 2018 | 04:05 AM
Transman304's Avatar
Thanks for the update. Hope it works out for you.
Old Mar 30, 2018 | 08:26 AM
Last night it was running and driving good then I gave it a little peddle hers a clunk and lost all forward gears but reverse is fine I’m guessing the tranny is toads but is their anyting to try?
Old Mar 30, 2018 | 09:13 AM
I pulled the fuse and now I have 3 gear, is the tranny toast or should I try something befor I junk it?
Old Mar 30, 2018 | 10:13 AM
It sounds like you squeezed the life out of it. Lol! No more magic pills that I’m aware of. Good luck.
Old Mar 30, 2018 | 10:23 AM
How hard would it be to put another 4l60e in it?
Old Mar 30, 2018 | 12:32 PM
Very doable for someone that has had some mechanical experience. Going to need A few tools as far as hand tools 2-3 ft extension, swivel sockets if you have the will make the job a little easier. You need a way to support and lower transmission. The plug on the neural safety switch will need to be heated at the connector.s with heat gun or lay a drop light next to it for a while to soften the sealer so you don’t break the switch. Be sure to flush cooler lines and cooler in radiator and external cooler if equipped. Torque converter has to be completely seated in pump or major damage will be done. That’s just the minimum of things to do. Good luck.
Old Mar 31, 2018 | 07:22 PM
Are the blazers transmissions interchangeable? Like would a 95 or 99 transmission fit in a 97?
Old Apr 1, 2018 | 04:46 PM
I just read something about a key won’t come out of the ignition switch and he had no forward gears, I have the same problem my get is stuck and I have no forward gears, I only have 3 if I pull the tranny fuse, could it just be the ignition switch??? Thank you
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
