transmission fluid cooling lines please help!!!
Old Jan 30, 2013 | 10:36 AM
mitchell27's Avatar
mitchell27 is on a distinguished road
Exclamation transmission fluid cooling lines please help!!!
hi am wondering which of the two tranny lines is the tto and return line the top or bottom im really stuck!! someone put a inline filter on the top line and im looking to replace it but i need to know the flow direction
2001 4.3l 4dr
Old Jan 30, 2013 | 11:13 AM
newguy's Avatar
Top is return bottom is output
Old Jan 30, 2013 | 12:16 PM
neo71665's Avatar
On the 700R4 the bottom fitting on the right side of the transmission is the "out" line to the cooler and the top fitting is for the return line from the cooler.
I have mine set up so the line from the bottom fitting goes to the top of the radiator cooler. Then a line exits the bottom of the radiator cooler and goes to a remote transmission filter (screw on type -- I also have the internal filter installed in the transmission). From the filter the line goes to the top of the auxiliary cooler. Then there is a return line from the bottom of the auxiliary cooler back to the top fitting on the side of the transmission.
kendog
18
Jun 12, 2018 06:18 AM
rseckinger
May 17, 2011 07:29 PM
DillonO
May 15, 2009 10:17 AM
ejschultz
Apr 19, 2009 01:43 AM
mel
Jan 20, 2006 08:21 AM
