Transmission fluid and filter
How hard is it to change the trans fluid and filter?
I was told by a friend that the back of the transmission had to be jacked up or something. And also that there is a cross-member of some kind???
Any ideas?
Thanks.
Any ideas?
Thanks.
It's a super easy job, start at the front or back of the pan and loosen the bolts in kind of a staggered pattern. You want to tilt the pan to one side to drain the old fluid, if you catch what I'm saying.
Then after the fluid is drained just remove the pan carefully, a good bit of fluid will still be in there. Pull off old filter, push on new one, new pan gasket, install pan, and fill it up with fluid.
Now, I always install a drain plug in the pan when I pull it the first time. It's really easy to do, I get a oil pan drain plug with rubber O-ring and a nut to fit it, find the lowest spot in the pan and drill a hole the same size as the bolt, insert the bolt and nut in the pan, and either epoxy, JB weld, or tack weld the nut inside.
Next time you want to change the fluid & filter in the tranny it's a clean and simple job.
Drain plug. Thats good thinking. Im totaly doing that. Dude should work for GM.
My crossmember is that way....I just loosen the trans mount bolt and then push up on the tail shaft with my hand to give me the little extra room that I need. I thought about cutting the lip off and being done with it but, never have.
Installing a drain plug is a good thing to do...but, they do make a kit to do just that on the trans.
Thanks for the advice guys.
I had the little lip on the crossmember. Cutting wheel took care of that lol
LannyL81
02-27-2012 11:58 AM
boondoggle
12-15-2010 08:36 PM
navyblue_sk8er
02-22-2008 09:17 PM
