transmission flush help
As anyone else tried the method for a transmission flush that 6700 describes in his first post? I haven't seen this method in any internet searches, but it seems to make sense. Are there any risks doing it this way? I haven't noticed any transmission problems, but I know that the fluid has not been changed since I've had the truck.
Nice. Once I can get the materials together, I'm going to do the flush on both of my cars. Question: Is there anything special that needs to go on the threads of the cooler lines before reinstalling in the radiator? I was looking at it yesterday, and it looks like there is some sort of tape on the threads, like plumber's tape, or it could be something else.
k i did the tranny fluid change and it came out so dark but then started running red around the end of the 2nd gallon and start of the 3rd gallon.
my 10 yr old helped me out he is actualy realy helpful, well the blazer runs shifts alot better o and i put the aftermarked aux cooler on.
i put a clear hose comming from the output of the tranny and just poured fresh in the filler as it was comming out at about the same rate and all went well.
then i cut my rubber tranny line to lengh and installed the cooler.
btw remote start helps so much when doing this
now i can play
with my new car.
thank you blazer community.
now i can play
How can i tell if antifreeze is leaking into my tranny for sure?
First, which tranny line do you unhook that drains the fluid? is it right at the raditor or under teh truck? if its at teh radiator is it the top or bottom?
And will unhooking the other line and putting it into the new fluid suck it in while the truck is running intsead of putting a tube into the dipstick filler tube? or do you have to put it in the dipstick filler tube?
And how did you hook up a external tranny cooler? where did you buy it and what did you need to do it? and where did you mount it? thanks
I may be able to answer your flush questions, as I just did a one this past weekend. I have a 2000 Jimmy, so the configuration may or may not be the same, though. I unhooked the top ATF cooler line on the passenger side of the radiator. I was actually expecting this be the line that fed the radiator from the transmission, but when I turned on the engine, ATF started shooting out the radiator. What mess. This was actually better this way, though, since I could flush out the radiator of old fluid. So attached my hose to the radiator, and into a bucket marked in quart increments. From what I've learned from others on this site, the method of sucking in the new fluid into the other cooler line will not work. The pump only pumps fluid into the radiator, it doesn't have the ability to suck it into the transmission. So you must pour the amount that is pumped into your bucket into the filler tube. That's where the increments come in. I stopped the engine after every second quart and poured in two new quarts. I think I may have overfilled though, so be careful. Sorry I can't answer your other questions, I'm sure someone else will.
edit: One thing I forgot, don't lose the e-clip when disconnecting the cooler line. I actually did lose it, but I was prepared , since I had bought a new connector that came with a new clip.
hroofblaze96
Jan 15, 2020 04:39 PM
lizardking88mph
Aug 20, 2011 01:18 PM
pfsantos
Sep 23, 2010 03:58 PM
portcqb
Apr 29, 2008 09:56 AM
ZR 2
Dec 4, 2007 03:53 AM
