Transmission help!!!!
Old Oct 29, 2011 | 10:42 PM
jpsny108's Avatar
jpsny108 is on a distinguished road
Default Transmission help!!!!
ok I got a 2001 blazer It's got the 4L60E trans. I started to have a little slipping in high gear around 60mph @2,000 rpm so I changed the filter and fluid today went for a 35 mile drive and it started to slip even more now it shifts 1st to 2nd fine but goes to shift to third and kinda heaitates to shift a little but still shifts and from third to forth is kinda hesatent and drops to 1500 rpm with no power the passing gear works fine I don't under sand it I got NO exp. with tranny's at all please help
Old Oct 30, 2011 | 09:26 AM
gatorboy44's Avatar
gatorboy44 is on a distinguished road
You're probably best off taking it to a shop if you have no experience with it.
Old Oct 30, 2011 | 04:49 PM
jpsny108's Avatar
thats fine if you can afford to take it to one I can't I'm more of a DIY kinda guy anyways
Old Oct 30, 2011 | 05:52 PM
gatorboy44's Avatar
If the transmission fluid is brown, something is falling apart and you need a rebuild.
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
chris24301
Nov 21, 2006 05:11 PM
1badSRAD
Sep 14, 2006 04:31 AM
goken50
Feb 13, 2006 04:35 PM
