Transmission Help
Old Sep 24, 2013 | 03:58 PM
NAGES1425's Avatar
NAGES1425 is on a distinguished road
Default Transmission Help
I am debating what the best transmission would be the best to put with my 350 in my blazer. Can someone spread some light on what they recomend, and why. And just some general information
Old Sep 26, 2013 | 09:31 PM
TZFBird's Avatar
TZFBird is on a distinguished road
What transmission is currently in it or what did you take out? What year is the vehicle and are you running EFI?
Old Sep 27, 2013 | 09:14 AM
NAGES1425's Avatar
I bought it without a transmission in it. Its a 93. But i am putting a 78 target master carberated engine in it
Old Sep 27, 2013 | 09:44 AM
TZFBird's Avatar
Since you are going carb you could probably go either TH350 or 700r4. Running the TH350 will probably require relocating or modifying the crossmember mount. Running the 700r4 would mean you will need to pick a non-lockup converter or else the converter lockup kit which is used with a carb engine. This comes in two styles one which just uses a toggle switch and is operator controlled, but the other is installed in the vavle body and will lock the converter automaticlly. The Th350 uses vacuum as a shift refrence and the 700R4 uses a TV cable as a link between throttle position and shifting.
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
chris24301
Nov 21, 2006 05:11 PM
1badSRAD
Sep 14, 2006 04:31 AM
goken50
Feb 13, 2006 04:35 PM
