Transmission HELP!!!
Old Oct 16, 2013 | 02:46 PM
s33n3w's Avatar
s33n3w is on a distinguished road
Default Transmission HELP!!!
I have a 2004 Blazer LS 4WD.
The transmission (4L60E) has been slipping for a while and i just haven't been able to save up enough to rebuild it. It is my daily driver and starting this morning, it will not engage in third...
Could someone point me in the right direction as to a detailed manual that would give me step by step instructions on removal, rebuild, and re-installation?
I cannot afford to have it rebuilt by someone else and I really don't know enough to just wing it.
Please help...
Old Oct 16, 2013 | 03:13 PM
chris015's Avatar
Honestly,if your having to ask how to remove it,the rebuild is not for you. Dont take this as offensive. Ive seen alot of people "try" and end up spending double and lots of headaches. As i did when i first started out. Too many things that can go wrong. Also,the special tools you need cost a few pennies,and by the time your done,IF it works you will have 4-500 bucks in it. If it doesnt work,you did all this for nothing,and you cant get any money back. you could go with a used transmission for about the same or less,and have a warranty. A decent rebuild kit is 300 bucks,plus special tools,and the huge gamble your taking. Give me your zip code and i can look at the used transmissions in your area in the yard data base and i can help you find a replacement.
Old Oct 17, 2013 | 09:48 AM
s33n3w's Avatar
That'd be great. I can get it out and back in, it's just the rebuild I'm nervous about. Swapping won't be an issue.
My zip 79416.
Where can i find the yard database? for future reference...
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
chris24301
Nov 21, 2006 05:11 PM
1badSRAD
Sep 14, 2006 04:31 AM
goken50
Feb 13, 2006 04:35 PM
