Transmission installation
Old Aug 29, 2011 | 01:18 PM
dreadinger's Avatar
dreadinger is on a distinguished road
Default Transmission installation
1995 blazer 4x4 4l60e. I am trying to install a transmission in my driveway, I jacked up the blazer high enough so I could slide tranny and floor jack under the frame and then lowered it back down leaving me the bare minimum to work under there and the tranny is still about 6" to low to bolt up. I could rent a tranny jack but I don't think I could lift the blazer high enough to slide it under. any idea's. I wasn't the person who removed it so I don't know what they did.
Old Aug 29, 2011 | 02:53 PM
Lift the trans up as high as you can using your jack. Support it on blocks of wood and/or jack stands at that height. Lower the jack. Build a suitable support out of wood that will allow you to raise the transmission up to the proper height using it between the jack and the transmission.
strubby
Oct 17, 2006 09:07 PM
cowboy35002003
Sep 17, 2006 11:03 PM
Hanr3
Engine & Internal
Aug 18, 2006 12:36 AM
ivannj
Feb 17, 2006 03:36 AM
pengifyd
Nov 15, 2004 11:01 AM
