Transmission Interchange
Old Aug 16, 2010 | 07:40 PM
garyrsch's Avatar
garyrsch is on a distinguished road
Default Transmission Interchange
Hi all
I recently aquired a 1995 s10 Blazer 4x4 automatic. The trans is bad. The door sticker says date of manufacture is 04/95. The trans has the raised letters PMW behind torque converter. So with that said can anyone tell me what years will work for this truck?
Thank you in advance for any help.
Old Aug 16, 2010 | 10:42 PM
You should be able to use a transmission from any '96 or newer (or '95 PWM equiped) truck. Somewhere in '96-'97 they changed to a two piece main case with a full circle front bell housing and a 6 bolt rear flange. To mate your transfer case up to the 6 bolt rear flange, you would need an adapter from an equivalently equiped newer truck. I am not sure if the adapters were the same for all of the various transfer cases used in the s-series vehicles, but they may be.
Old Aug 17, 2010 | 10:52 AM
garyrsch's Avatar
Thank you very much for the info. Really Appreciated.
DFINE160
Dec 7, 2009 12:17 PM
eelding
Apr 26, 2007 12:20 PM
MNHawk
Dec 21, 2006 09:38 PM
MIKE82
Nov 15, 2006 02:16 AM
ginobass
Sep 11, 2006 05:16 PM
