transmission in limp mode?
Old Nov 30, 2010 | 09:39 AM
cakes227's Avatar
cakes227 is on a distinguished road
Default transmission in limp mode?
My girlfriends 1995 chevy blazer 4x4 with automatic transmission is not shifting past second gear. I did some research and found out that it may be in limp mode. What can cause limp mode on this vehicle? Can I check why it is in limp mode by checking for an error code? If so, how do I check for an error code, because I went to have it checked some time ago at autozone because of a rough idle and he said he could not check it because the 1995 chevys have an OBD II port but an OBD I computer, or something like that, I didn't look into it any further because the problem corrected itself. Any help will be greatly apreciated.
Old Nov 30, 2010 | 09:59 AM
A check of the stored codes may give you some insight into the problem if the problem is electrical. But the problem may be a bad 3-4 band.
Old Nov 30, 2010 | 10:35 AM
cakes227's Avatar
Oh, I forgot to mention, the transmission was rebuild a little less than a year ago after having symptoms very similar to, if not exactly the same as these. I don't know exactly what the problem was when it had to be rebuild, but I guess if these are symptoms of a bad 3-4 band, thats probably what it was. Maybe the mechanic did a shotty rebuild and the 3-4 band went bad again. Too bad its a 3.5 hour drive from the guy that fixed it.
dannyb91979
Oct 1, 2013 01:10 PM
dready1084
Mar 12, 2010 10:10 AM
mrblonde108
Feb 4, 2010 11:36 PM
BlackFireLS4.3
Jan 29, 2010 10:00 PM
deadgoon20
Oct 30, 2008 02:03 PM
