Transmission line leak.
Old Jan 1, 2009 | 10:50 AM
brothertonk's Avatar
brothertonk is an unknown quantity at this point
Default Transmission line leak.
i just posted a previous post about how my blazer was over heating. i ended up buying a new radiator. got everything put back together. hoping it would work out. i go to start it and i look under the car and i notice transmission fluid dripping. i spotted where it was coming from. its coming from a hose connected to the transmission line bracket that comes from your radiator to the actual line itself. i took it off and it seems like the actual line has been cut in that spot from a previous leak and repaired with a rubber hose. i dont know much about it but im not sure if the transmission line is a solid metal line or if there indeed was a hose there. i bought a new hose and a few more clamps. got them put on like the old one. STILL leaking. but even worse now. im not sure if the transmission line is a pressurized line or what. or if you need some type of sealant with the hose. idk. but im pretty sure im going to have to buy a new line. but before i go doing that. any ideas??
Old Jan 1, 2009 | 11:00 AM
mrafindley's Avatar
mrafindley is an unknown quantity at this point
Default RE: Transmission line leak.
go to the hardware store and get yo either a flaring tool a flared nut and a hose barb to connect to your new flare or use compression fittings and a hose barb
Old Jan 1, 2009 | 11:07 AM
not too sure what the hell those are lol. but i am going to write this **** down and go check it out and see if it will help. thanks
Old Jan 1, 2009 | 04:35 PM
Stock was hard line all of the way. Sounds like someone twisted the end off of the transmission line at some point and did a quick repair job. A slight flare on the end of the line will allow for a better seal, but it is better to either put a full flare on it or to use a slip on compression fitting. The compression fitting is the easiest to do on an old line, just make sure that the line is clean where the fitting goes on.
Old Jan 2, 2009 | 04:15 PM
Hanr3's Avatar
Have you tried tighening up the clamp?
I would use two clamps on the repair side of the hard line, and one on the fitting end of the rad. You may have them too tight, but I doubt it. Are they new clamps?
BubbaBrooks
May 18, 2011 08:38 PM
rastaskater
Jan 29, 2008 08:32 AM
Flyinsooner
Dec 8, 2007 10:49 AM
pilgrim
Engine & Internal
Nov 14, 2006 02:06 PM
STEVE1103
Engine & Internal
Apr 3, 2006 03:53 PM
