transmission lines
Old Jun 24, 2012 | 10:41 PM
deathrider's Avatar
deathrider is on a distinguished road
Default transmission lines
how to replace lines on a 2001 blazer
Old Jun 24, 2012 | 11:17 PM
Rottidog's Avatar
Look & take pics where they are, how they're clipped in & to what where, how they're routed. Get OEM lines, new filter & oil, pan to catch old oil & make sure you have the right sized combination wrenches & sockets. Some sort of Sorb-All or kitty litter stuff for oil spills wouldn't be a bad idea either. After loosening the trans pan & draining the oil (great opportunity to change the oil & filter) remove 1 line at a time. If you purchased OEM replacements then they'll be pre bent & should only be able to go in one way.
If you don't want to go through all that then just replace the lines without draining the oil. I'm pretty sure they're above the level of the oil pan. Just check the trans fluid after & top it up as needed.
Have you tried searching in here?
Old Jun 27, 2012 | 02:57 PM
deathrider's Avatar
do i have to drop the transmission to replace tranny lines on a 2001 blazer
Denominator
Jun 5, 2009 07:00 AM
Ugly_Monkey
Mar 8, 2009 09:31 AM
stevelknievel
Apr 29, 2007 05:34 PM
broke33
Mar 18, 2007 08:03 PM
