transmission noise and no reverse
Old Apr 19, 2011 | 10:02 PM
submuzik's Avatar
submuzik is on a distinguished road
Default transmission noise and no reverse
Hi i have A 2001 CHEVY blazer.....I started it up like any regular morning and shifted it into reversing and it started whining noise and then wudnt go back.....I didn't think anything of it then I started driving and I notice it wud get up to 300 rpm then wudnt shift...until I took my foot off the gas....I don't know what's wrong and really need help because I love my truck....when I first start it and its in park u can kind of hear a whining noise come from the transmission.....HELP!!!!!!!!!!!!!
Old Apr 19, 2011 | 11:51 PM
chris015's Avatar
Check your fluid?
Old Apr 20, 2011 | 06:53 AM
Sounds like the infamous broken sun shell. If your fluid level (checked with the engine running and the truck on a flat level surface) checks out ok, you are likely in for a tear down if not an all out rebuild.
Old Apr 20, 2011 | 10:27 PM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
x2 on the sun shell gear, do you have 1st or 4th gear? when mine when out (sun shell gear) I had no 1st and I cant remember if it wold go into 4th or not
Old Apr 23, 2011 | 05:57 AM
JHON's Avatar
JHON is on a distinguished road
My 2000 Blazer won't move in reverse, I check the fluid and it was little to none in there. I put 2 quarts in and it still won't go in reverse...do I need more fluid or a new transmission. When I took it to the shop he stated that the codes were saying engine...but that I most likely needed a new transmission. I need some advice.
Old Jun 12, 2011 | 12:27 AM
submuzik's Avatar
I can go fine.......I have to let it go to about 2500 rpm then take my foot off the gas for it to switch gears...
kris37fire
Jun 11, 2014 09:13 PM
upmaine
Jul 14, 2012 01:03 PM
199634
Apr 20, 2011 02:09 PM
dj00140
Apr 13, 2011 10:40 AM
ricks
Oct 4, 2010 07:49 PM
