Transmission Noises
Old Feb 1, 2010 | 06:34 AM
yarinzim's Avatar
yarinzim is on a distinguished road
Default Transmission Noises
Hello! I'm driving a K5 90'. my transmission makes banging noises when i push the gas paddle, and between changing gears. i checked for oil of course, any ideas what could be the problem? i have little understanding in this compartment.
Thanks in advance, yarin.
Old Feb 1, 2010 | 08:44 AM
Sway_89S10's Avatar
Sway_89S10 is on a distinguished road
I'm no expert on transmissions, but it could be metal debris in the tranny, which would mean clutches are worn. The only way I know of to check is to pull the pan and see if there's any metal in the fluid or in the filter. Anybody else, please feel free to correct me if I'm way off.
Old Feb 2, 2010 | 01:45 AM
yarinzim's Avatar
let's say that i drained all the oil out and found debris in the filter - what do i do next?
Old Feb 2, 2010 | 06:49 AM
Sway_89S10's Avatar
Change the filter and put new fluid in
Old Feb 2, 2010 | 09:00 AM
yarinzim's Avatar
oh, so what you mean is that the debris are making the bangs that i hear in the transmission or what?
Old Feb 2, 2010 | 09:24 AM
Sway_89S10's Avatar
Well, like I said, I'm no expert on transmissions, but I would imagine metal debris spinning around in there would make some kind of noise. But I suppose it could be any number of things, a bent input/output shaft, a warped sun gear, or it might not even be the tranny come to think of it, could be a bad U-joint. Do you have any hard shifts, or missed shifts, or clutch slippage?
Old Feb 2, 2010 | 12:33 PM
yarinzim's Avatar
well the transmission works fine, no mishaps what so ever. only an occasional bang.. my u joints are tight as well..
yarinzim
13
Sep 3, 2010 08:28 PM
bdscholes71`
Oct 7, 2007 02:59 PM
frankjc
Feb 11, 2007 09:04 PM
drefda
Oct 4, 2006 05:31 PM
2001blazer
Mar 29, 2006 01:51 AM
