truck turn off under hard braking?
Old Feb 1, 2010 | 05:33 PM
noseback's Avatar
noseback is on a distinguished road
Default truck turn off under hard braking?
i can't figure out why but when i slam on the brakes the truck turns off, last time i did that was to avoid an idiot who jumped infront of my car at the last second and the whole thing shut off. after that i thought maybe because i had almost less than 1 gallon left in the gas tank, filled it up and tried it again on a empty road and sure enough the truck turned off when i slammed on the brakes....any idea's on what could be the problem?
i had recently changed the water pump, thermostat, radiator, altinator, starter, egr valve, battery, new front rotors, pads and calipers, new drums and shoes, properly bleed the system, new power steering pump. never really thought about this problem till now... i want to get on it before summer arrives.
Old Feb 2, 2010 | 07:02 AM
ChrisC's Avatar
ChrisC is on a distinguished road
Does the battery hold a charge well? For what reason did you change the alternator? Any major vaccum leaks around the brake booster? Any check engine lights? I assume this is a blazer. :P I had this same problem on an old camaro I used to drive. It had a weak battery, and If I stomped on the brakes the revs would drop out and it would stall, then about a week, later the fuel pump quit heading down my bumpy driveway.
I would have the battery tested and then test the fuel pressure.
Old Feb 2, 2010 | 11:47 AM
noseback's Avatar
yea the battery is holding charge, the altinator was changed for my own reason i wanted most of the mechanical parts in new condition as i am going to use the truck for long state to state driving all summer long.
no vaccum leaks any where that i can see or hear near the brake booster, no CEL and yes is a 95 blazer 2dr 4x4. i will look into the fuel pressure as soon as i can. thanks
Old Feb 2, 2010 | 11:54 AM
wlorton's Avatar
What year is the vehicle? That may help a little
Old Feb 2, 2010 | 12:59 PM
bigjon1's Avatar
bigjon1 is an unknown quantity at this point
It could very well be a vacuum leak somewhere. Braking in general, and especially hard braking take a lot of vaccum. Check to see if you have any dry rotted, cracked, broken, or missing vacuum lines.
Old Feb 2, 2010 | 03:15 PM
noseback's Avatar
sorry its a 95 blazer 4x4 2dr LS model
er0ck273
Jul 31, 2015 04:10 PM
BassHog
Sep 22, 2014 01:47 PM
Escohomie
Apr 7, 2012 04:48 PM
Jmooney152
Jul 18, 2011 08:57 PM
542jerry
Apr 28, 2008 09:27 PM
