transmission? oil leak please help. Pics
Old Jan 6, 2012 | 06:24 PM
louiepb's Avatar
louiepb is on a distinguished road
Default transmission? oil leak please help. Pics
hey all i noticed some oil on my garage floor, and decided to take a look under my 98 4x4 blazer and found a slow oil leak underneath. would anyone have any idea on what it is? if its any help i just installed a airid intake system a couple weeks ago.
thanks in advance
these pics are from underneath the passenger side:
Old Jan 6, 2012 | 06:32 PM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
Mine has a similar
leak so I changed my valve cover gaskets and it slowed down but did not go away. Any more Ideas would be great
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
The First thing I would do (and you may have checked this) but I would make sure the drain plug is tight. Is where the Oil pan mates up with the block covered in oil?
Old Jan 7, 2012 | 12:13 AM
Gale's Avatar
Gale is an unknown quantity at this point
You need to make it oil free then start looking for the leak.
Beware Blazers are leakers.
Old Jan 7, 2012 | 09:34 AM
TheRandom1's Avatar
Gale has the right idea. Clean the bottom of the motor really well so there isn't oil all over the place.
You can actually get a UV additive you can put in the oil. Run the motor for a little bit until it starts seeping again, then use a UV flashlight to see where the UV dye is at. It should show you where your leak is starting.
bogborn
May 22, 2012 09:37 AM
BubbaBrooks
May 18, 2011 08:38 PM
cory.kiel
Apr 20, 2011 06:52 AM
87Blaze
Apr 17, 2011 08:01 PM
jiggs240
Apr 15, 2011 03:09 PM
