Transmission slips P1870
Old May 22, 2009 | 01:14 PM
uberfiend's Avatar
uberfiend is an unknown quantity at this point
Originally Posted by kiwiblazer
I get around 18 litre per 100km (12/13 US mpg) Highway a bit better.
I was getting around 18. Now it's down to 14.
Old May 22, 2009 | 11:24 PM
hkellogg's Avatar
hkellogg is an unknown quantity at this point
you are better off finding a local Transmission shop and having the trans work done or replaced by them, truthfully a jasper reman isn't a bad thing, I paid $1800 for a new trans last june in my truck I had 165,000 on the original and knock on wood I haven't had a problem since, I would reccomend gettting cooler lines installed and running a b&m auxillary cooler in front of the radiator it will help with your trans staying healthy
Old Aug 16, 2009 | 04:34 PM
arlonadkinson's Avatar
arlonadkinson is on a distinguished road
If you like go ahead and let someone sell and replace your transmission but here is my suggestion! Check around and see if you can find a minor vacuum leak! This can simply be the big round hose that goes from the fuel injection to the power brake hub! This is normally a push in connector which has about a 1/2 inch hose clamped on it! If there is any kink or the connector is not in correctly a leak will occur and the transmission will shift rough as though you will be thrown out of the vehicle! Try unplugging this connector and plug it back in hard and straight and maybe you will be lucky and fix your problem. If the vacuum is correct your transmission will shift better than you have ever experienced!
cmchutch
Sep 13, 2013 09:41 AM
karmtec
Aug 15, 2011 02:01 PM
robrote
15
Jan 7, 2010 07:37 AM
kiwiblazer
Aug 17, 2009 06:19 AM
Sparky
Jan 13, 2007 09:08 PM
