Transmission stuck in 1st
Old Feb 25, 2012 | 11:25 AM
ptg327's Avatar
ptg327 is an unknown quantity at this point
Default Transmission stuck in 1st
Recently bought 1999 GMC Jimmy 4.3 with 4L60E. Purchased the vehicle knowing that I would have to let off the gas to let it shift into every gear when driving. Example would be that I would start in first let off the gas for a second and it would go into 2nd and so on... Well I tried to drive out of a parking spot the other day and nothing. Would not move. Checked fluid and it was empty. Filled it and found a leaking cooler line. Fixed the leak put a quart of Lucas trans fix in and nursed it to auto zone to top fluid off. Now it won't shift out of 1st. Not with the pedal or manually. Any help would be greatly appreciated.
Old Feb 25, 2012 | 01:14 PM
ptg327's Avatar
Also the Speedometer, Tachometer, Reverse, Neutral, and Tow/Haul work. My research is leading me in several different directions but nothing definitive.
Old Feb 26, 2012 | 06:15 PM
ptg327's Avatar
Looks like it will go to the tranny shop so I don't throw parts at it without knowing the cause. Will post the findings to help anyone with this problem in the future.
Old Feb 27, 2012 | 03:15 PM
ptg327's Avatar
It's dead, Drove it when very low on fluid. The inside is destroyed
stingray74
Mar 5, 2015 08:27 PM
Blessed23
Jan 14, 2011 08:09 AM
98odgblazer
Aug 22, 2010 10:25 AM
moe78
Jan 20, 2010 05:59 AM
GloryImSaved
Jul 17, 2009 09:05 PM
