Transmission Trouble??
Old Nov 9, 2008 | 08:30 AM
jman_08's Avatar
jman_08 is an unknown quantity at this point
Default Transmission Trouble??
Hey gueys alright this morning its very cold out about 20 degrees went to start my blazer was driving it and it was driving fine then. Out of nowhere my transmission does something very weird it has been doing this for awhile but not this bad. What i am experiancing is when i stopped at a red light i went to take off engine revs then truck jerks a couple times then takes off but the engine revs before the truck moves.
So what is wrong with my transmission also for along time when i have gone very slow and went to take off there is a clunk somewhere is the driveline Could this be a ujoint causing the slipping event and noise i hear???
It also usually only does it when i go around corners is when it slips the most but todays it doesnt matter it took about 2 to 3 seconds before the tranny caught up and made the truck takeoff
Rev move a little then finally takeoff
Help Please
Thanks
Jared.
Old Nov 9, 2008 | 05:55 PM
jman_08's Avatar
Default RE: Transmission Trouble??
Anybody?? The blazer continues to do this and the transmission fluid is fine.
Old Nov 10, 2008 | 09:34 AM
jman_08's Avatar
Fluid also looks good it is in the crosshatches.
Old Nov 10, 2008 | 12:27 PM
noom14921992's Avatar
noom14921992 is an unknown quantity at this point
well i would not know. but i will say for some one to help you you will have to tell us what you drive(year,engine,drive train). thats all i can say and check the codes
Old Nov 10, 2008 | 05:28 PM
Hanr3's Avatar
Pre '93 check your TV Cable adjustment.
Post '93 take it to a shop.
sounds like a slipping toruqe converter, or a bad pump. Could be only a matter of time.
clunk is typically a u-joint.
Old Nov 10, 2008 | 07:39 PM
jman_08's Avatar
Sorry i keep forgetting to do that it is a 2004 S-10 Blazer 4x4. 4.3L
Old Nov 12, 2008 | 08:47 PM
CoolAirVw's Avatar
CoolAirVw is an unknown quantity at this point
Sure does sound like low fluid. Slips on turns and at stops? Fluid sloshes to the front on stops, and sloshes to the sides on turns, causing pump to get a big swallow of air. Pump cant make pressure with air so the clutches release then reapply with a bang when the pump gets fluid again.
Check the fluid again. Make sure your checking it right and make sure your getting a "true" reading.
Any leaks? Is the transfer case overfull? Fluid from the trans can "migrate" into the transfer case making it overfull and making the trans low.
Kingswede
Apr 17, 2011 08:11 AM
Crawlerchris
Jan 4, 2010 06:37 PM
hoffy015
Nov 30, 2007 10:17 PM
pilgrim
Jan 21, 2007 07:23 PM
blazerrick
Dec 21, 2005 04:19 PM
