Transmission Whine
Old Feb 21, 2008 | 07:36 PM
mrw81178's Avatar
mrw81178 is an unknown quantity at this point
Default Transmission Whine
New to Site. Have 99 Blazer with auto trans 61,000 miles on it. Mint condition always garaged. The last couple of months whiledriving the truck there seems to be a whine in all forward gears and reverse. No noise in Park or neutral. Noies increase when RPM's increase, seems less noticeable at higher speeds. Truck dosen't get used alot, sits in garage. Fluid level is good, looks fairly clean not burnt. Any suggestions or is this a normal occurence after 60,000 miles. Thanks for your help.
Old Feb 21, 2008 | 07:42 PM
WolfPack's Avatar
Default RE: Transmission Whine
Welcome to the site! Get some pics up of your blazer, it sounds pretty nice!
As for your problem, how are you sure it's the tranny? Have you taken any steps to eliminate other sources in the wheels?
Old Feb 21, 2008 | 07:43 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
I would give the hunch that theres sumtin wrong with the torque conv.. even tho its garaged means nuttin.. a tranny can go even when babied... or not from usage..
Old Feb 22, 2008 | 03:49 AM
mrw81178's Avatar
Thanks for the suggestions. The noise is there when the truck is not moving so that eliminates wheel movement causing the whine. I was able to get some info from GM and one of their SIB's addressed torque converter whine and how to distinguish the difference between that and other symptoms, but did not really say what causes the whine. Maybe I am to **** retentive! HaHa. Any other input would be helpfull. Getting snow here in CT. Great site
Old Feb 22, 2008 | 04:16 PM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
Usually when a transmission whines the front pump is on it's way out 9 times out of 10 !
Zed
Old Feb 22, 2008 | 09:44 PM
Hanr3's Avatar
^ Ditto
If it's the transmission whining.
Old Dec 31, 2009 | 08:15 AM
GLBL WMR's Avatar
GLBL WMR is on a distinguished road
I think my front pump is going because it started whining a few weeks ago. It whines in all gears, even park and neutral. It doesn't do it immediately at start up after its been sitting for a few hours, but 5-10 minutes into a trip, its there. It also slips under harder acceleration in the 1-2 shift when its not warmed up. Once its warmed up, it doesn't slip. Can this also be caused by a bad pump? The tranny fluid looks/smells ok. I plan on selling the truck within 4-5 months (3000-4000 miles) - should I gamble on this one and not fix it? I don't have the resources to do it myself - what is this going to cost in parts and labor at a reputable shop?
Billyclubz
Feb 7, 2012 06:04 AM
eldodw
Sep 11, 2011 09:34 PM
Eff10
Sep 13, 2009 10:23 AM
Rye Dude
Aug 13, 2009 12:32 PM
LuckyD
May 16, 2009 09:20 PM
