transmission wont shift I think a ground issue
Old Jul 25, 2018 | 10:50 PM
101 orchard ave's Avatar
101 orchard ave is on a distinguished road
Default transmission wont shift I think a ground issue
hey guys thanks for looking
I have a 1993 GMC S-15. Here are the symptoms
No power to the instrument cluster
Turn the lights on and the alarm beeps as if you took the key out and left the lights on
Truck stuck in 3rd
I think its a ground issue but where do I find the ground? Is there a place where they tranny and instrument cluster ground together?
Any help would be appreciated
thanks
Old Jul 26, 2018 | 11:19 PM
Transman304's Avatar
The PCM ground is most times on the rear of the left cylinder head. May want to look at the fuse panel also.
good luck.
Old Jul 27, 2018 | 07:19 AM
thanks man
i just dont know what would cause the cluster to go dead and the lights to alarm when i put them on. Im thinking it has to be a ground or a short. Im not positive but a bad **** solenoid shouldn't effect the lights or the other gauges on the cluster.
what are your thoughts ?
Old Jul 27, 2018 | 08:11 AM
lol! After 40 years of this stuff you think you’ve seen it all but have learned never to rule out anything. You could unplug the transmission at the case connector and then try the light switch to rule out the electrics in the transmission being involved.
THines22
Jan 26, 2018 08:07 PM
dgriffinhere
Feb 10, 2017 09:20 PM
Nunes Martinez
Feb 28, 2013 08:28 AM
riotousness
Jul 15, 2010 05:41 PM
rdhack
Jun 7, 2009 03:38 PM
