transmisson leak!!
Old Jul 9, 2010 | 02:54 PM
dkratt's Avatar
dkratt is on a distinguished road
Default transmisson leak!!
My 1996 chevy blazer 4x4 leaks transmisson fluid around the pan i know its the gasket but one of my bolts are stripped and is barley in there. But my main problem is that i have alot of bubbles in my trany fluid when i pull the dip stick. Im always adding fluid here and there but how do i fix it from bubbleing.
Old Jul 9, 2010 | 03:47 PM
bandidolenny's Avatar
Pull the pan and HeliCoil the stripped hole in order to fix the threads... also replace the filter while you are in there.
Sounds like you are foaming the fluid... A filter and fluid change may fix it but you may also want to do a full fluid flush once the filter is changed.
NOTE: do not let someone talk you into doing a full fluid flush without changing the filter.
Old Jul 9, 2010 | 04:23 PM
rriddle3's Avatar
*Please do not double post the same problem in multiple Forum sections, it is against the rules. You did read them, right?*
dkratt's Avatar
how do you do a full fluid flush?
Old Jul 9, 2010 | 04:24 PM
dkratt's Avatar
yes i did sorry just trying to find help fast
rjck1979
Dec 29, 2009 04:15 PM
rsither
Aug 13, 2009 10:29 AM
99 Blazer 4 door
Performance & Brainstorming
Aug 29, 2008 10:46 AM
SoDakBlazer
Aug 5, 2006 06:21 PM
BlaZeR FXB1581
Engine & Internal
Jan 27, 2006 07:45 PM
