trany
Old Feb 3, 2009 | 11:35 AM
oldschool4x4's Avatar
oldschool4x4 is an unknown quantity at this point
Default trany
Hey guys the trany on my 83 s-10 blazer 4x4 automatic wouldnt shift any higher than 2nd so i pulled the pan to see if i might have burnt up the clutches but the fluid is still red and there is no shavings in the pan or filter, what should i look at next?
Old Feb 3, 2009 | 03:48 PM
bamablazer57's Avatar
bamablazer57 is an unknown quantity at this point
Default RE: trany
i had the same problem for my 2000 but it ended up being the sun shell. after replacing it no more probs tho. usually if its the sun shell the truck will have no reverse or 3 or 4th depending on what else broke.
Old Feb 3, 2009 | 07:40 PM
Default RE: trany
This maybe a stupid question but i dont now alot about tranny's, whats a sun shell?
Old Feb 4, 2009 | 06:59 AM
Default RE: trany
When a reaction sun shell goes, it takes out reverse, 2nd, and 4th gears. The reaction sun shell is a hard part inside the transmission. Unless you want to get into the gritty details, I will leave it at that.
Old Feb 4, 2009 | 09:59 AM
IROCZ's Avatar
IROCZ is an unknown quantity at this point
Default RE: trany
ya youyr tranny is done ive had the same problems just ended up buying a used one and had no more problems. i found a used one for 200
Old Feb 4, 2009 | 11:32 AM
Default RE: trany
Well I dropped the trans pan and there was know shavings or anything in the pan and the trans fluid was nice and red, which is making me believe that its something else. Any more suggestions?
Old Feb 4, 2009 | 12:51 PM
jeepmudbogger's Avatar
jeepmudbogger is an unknown quantity at this point
Default RE: trany
mine is having the exact same problems. i am in the process of looking for a master rebuild kit and the sun shell. not all sure what i need to get. since i dont know a lot about trannys either, i dont know what all i should try to find in the rebuild kit. anyone care to help?
Old Feb 5, 2009 | 11:15 AM
952doorproject's Avatar
952doorproject is an unknown quantity at this point
Default RE: trany
hey i just bought a 1995 blazer 4x4 i had it to weeks and i was messing around a little bit spinning....
then i was driing down the road and lost everything it would not move but before i lost everything it was slipping going down the road any ideas ??
Old Feb 5, 2009 | 10:40 PM
Default RE: trany
alright guys i have got a newer year model chevy 4x4 S-10, the same bodystyle as my 83 but with a EFI 2.8L and a 5 speed manual tranny, what kind of problems will i run into puttin the clutch in the cab?
BigMarcus
Oct 29, 2007 09:26 AM
mdemers2006
Jul 26, 2007 06:41 AM
MNHawk
Jul 9, 2007 11:00 AM
mikehillis1@yahoo.co
Engine & Internal
Dec 19, 2006 12:45 AM
codereddanger84
Dec 11, 2006 11:50 AM
