trany temp
Old Nov 23, 2010 | 08:31 PM
spankyy's Avatar
spankyy is an unknown quantity at this point
Default trany temp
i was woundering cause non of the part stores around me sell trans temp gauges i was wounderin ig u could use a water/oil temp gauge insted
Old Nov 23, 2010 | 09:58 PM
TZFBird's Avatar
TZFBird is on a distinguished road
You could probably use an oil temp gauge, but a trans gauge has a specific range that it operates in. An engine does not rely on rubber seals and fiber material to operate, so temperature really does matter.
Old Nov 23, 2010 | 10:44 PM
69chevelle's Avatar
69chevelle is on a distinguished road
I use a ScanGauge II.
The Xgauge feature on it is awesome, can tell you tranny temp, water temp, milage, tps readings, timing, map readings, voltage, and many others. Can also read/clear codes.
there are also tons of site on the net you can order a tranny temp gauge from.
Old Nov 23, 2010 | 10:48 PM
spankyy's Avatar
how about a water temp gauge lol
Old Nov 24, 2010 | 04:43 AM
TZFBird's Avatar
If you really want to use one of those guages, just use it.
Old Nov 24, 2010 | 11:33 AM
spankyy's Avatar
no im just wounderin wat will happen i mean i have one of the gauges so i was just wounderin if it would work
zakm0n
Jan 9, 2011 07:31 PM
mdemers2006
Jul 26, 2007 06:41 AM
MNHawk
Jul 9, 2007 11:00 AM
mikehillis1@yahoo.co
Engine & Internal
Dec 19, 2006 12:45 AM
codereddanger84
Dec 11, 2006 11:50 AM
