Tries to crank only once - then gives up?!
Old Mar 11, 2010 | 10:31 AM
Johnny Glenn's Avatar
Johnny Glenn is on a distinguished road
Question Tries to crank only once - then gives up?!
Thanks for looking in - 95 Blazer 4.3L - the ultimate work vehicle, not road worthy anymore but still working hard until recently. It began sometimes to take several tries to crank but would run fine - Then it began to crank just once and when turned off will not crank back up. Now it will (cough) at first try to crank but then following tries - no cumbustion at all. I'm thinking fuel filter, fuel pump .... any ideas to try is greatly appreciated! Thanks.
Old Mar 11, 2010 | 09:15 PM
ChrisC's Avatar
ChrisC is on a distinguished road
Sounds like the ignition control module.
Old Mar 12, 2010 | 08:35 AM
thanks -- where is the module located and is there a way to test it? Any other possibilities?
Old Mar 12, 2010 | 10:18 AM
Find the ignition coil (only plug wire from the distributor that doesn't run to a spark plug) and it should be attached to the same bracket as the coil. It should have a heat sink on it.
djmehkae
Nov 7, 2017 08:08 PM
kb7qdi
Dec 17, 2012 05:54 PM
warthogdriver
Lifting Tech
14
Feb 28, 2010 06:00 AM
bigdawgz2006
Nov 20, 2009 03:47 PM
rickyp3278
Apr 12, 2008 12:00 AM
