Truck has trouble moving after engine swap
Old Mar 16, 2012 | 04:19 PM
Rando-s_R_and_C's Avatar
Rando-s_R_and_C is on a distinguished road
Question Truck has trouble moving after engine swap
I am doing a V8 swap into a 97 s-series. Ive got a problem, truck backs up fine but in order to move forward you have to rev it to about 1500 rpm. Its like the brakes are on but you can spin them freely when you jack it up. Its a small block carb motor. I hooked up the coolant sensor and a tps, and just left unneeded wires unhooked.
Old Mar 16, 2012 | 05:43 PM
pettyfog's Avatar
and is there a tach input?
Mind you.. still might not work right unless you hook it to a drac like the early 90 vss you need 3 pulses/rv instead of 4
Old Mar 16, 2012 | 06:06 PM
The wiring diagram I have does not show a tach input to the ecm. I'm new to here what is a drac?
Old Mar 16, 2012 | 07:19 PM
xgiovannix12's Avatar
hows the fluid level in the trans ? have you checked it after shifting into all the gears?
Old Mar 16, 2012 | 07:58 PM
pettyfog's Avatar
I'm not sure it cares about rpm but I would think it would. Reverse is purely mechanical, the forward gear shifting is by solenoid.
Old Mar 16, 2012 | 09:05 PM
fluid level is right where it needs to be. Its the 4L60E trans, don't know if that helps anyone.
bigdaddykane93
Jan 27, 2016 11:35 PM
chevylover5
Dec 24, 2013 08:31 AM
TigaHotty85
Jun 17, 2013 03:10 PM
bertrenolds
Mar 28, 2012 09:59 AM
TB2Blazer
Apr 28, 2011 06:44 AM
